About nissan pathfinder,1999
madBedex
Member - Posts: 17
Posted: March 25, 2005 at 9:03 PM / IP Logged
Hi! Guys.
I have a problem with the pathfinder.
I installed an after market alarm on it. But,sometime,the factory alarm goes off for no reason.
Would someone please tell me how to bypass it, because,i'm tired of the customer calling me all the time about the same thing over and over.
Or would someone please email me the diagram.
An advise would be greatly appreciated!
Any response would be so helpful.
Thanks!
madbedex
thepencil
Gold - Posts: 1,526
Posted: March 25, 2005 at 10:13 PM / IP Logged
1999 Nissan Pathfinder
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ purple        |+ |ignition harness            |
|          STARTER|BLACK / YELLOW        |+ |ignition harness            |
|   SECOND STARTER|RED / blue            |+ |ignition harness            |
|        IGNITION|BLACK/ white        |+ |ignition harness            |
|        ACCESSORY|WHITE/ blue          |+ |ignition harness            |
| SECOND ACCESSORY|RED / yellow          |+ |ignition harness            |
|       POWER LOCK|lt GREEN/ red        |- |keyless entry module *1     |
|     POWER UNLOCK|brown               |- |keyless entry module *1     |
|       LOCK MOTOR|blue               |   |keyless entry module *1     |
|     UNLOCK MOTOR|WHITE/ purple        |   |keyless entry module *1     |
|    DISARM DEFEAT|yellow/black        |   |keyless entry module *1     |
| PARKING LIGHTS +|pink/blue           |   |at steering column          |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|RED / black           |- |drivers kick panel          |
| TRUNK/HATCH PIN|tied in with doors |   |                            |
|        HOOD PIN|                    |   |                            |
| FCTRY ALARM ARM|yellow              |- |keyless entry module*1      |
|FCTRY ALRM DISARM|light green        |- |keyless entry module*1      |
|       TACHOMETER|blue               |   |at distributor              |
|      SPEED SENSE|WHITE/ yellow        |   |cruise module in DKP        |
|       BRAKE WIRE|GREEN/ YELLOW        |+ |at switch                   |
|     HORN TRIGGER|lt GREEN/ black      |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|blu/red - blu/blk   |A |drivers door switch        |
| RF WINDOW UP/DN|blu/yel - blu/white |A |drivers kick panel          |
| LR WINDOW UP/DN|RED / blk - grn/wht   |A |drivers kick panel          |
| RR WINDOW UP/DN|wht/blk - blk/wht   |A |drivers kick panel          |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 Keyless entry module is located under drivers side of dash.
Be careful whose advice you buy, but be patient with those who supply it.About nissan pathfinder,1999 - Last Post -- posted image.
