93 Seville remote trunk release?
jordache16
Posted: April 07, 2005 at 8:11 PM / IP Logged
i have a question about my 93 Cadillac Seville remote trunk release...
i recently baught the car and it came with an Astroflex keyless entry remote...
the question i have is i am curious as to why all the functions on the remote work(remote start, door locks, door unlocks) except for the trunk release button?
when i sit in the car and listen carefully i can hear a noise (somewhat like a clicking sound) coming from the area around the foot pedals when i press the trunk release button on the remote, (i assume the keyless remote sensor is trying to send a signal to the trunk relay) so i have to assume the car is recieving the signal and it is not a problem with the remote....also the trunk release button in the glove compartment works
i would like to know how to fix this problem or what i can do to get my trunk release on my remote to work
mo12v
Posted: April 07, 2005 at 8:18 PM / IP Logged
Shoul be a Relay around there going to the Factory harness wire :
Trunk ReleaseBLACK (+)RELEASE SW. OR DRIVER KICK PANEL
Check to see if is hooked up & check the Voltage
MO
mladams
Copper - Posts: 57
Posted: April 07, 2005 at 8:19 PM / IP Logged
it's probably not hooked up.  You would be best off to find a wire diagram for the alarm, trace the trunk release wire, and see if it's hooked up.  If it's not there's your problem.  Sounds like it's flippin a relay in the alarms module but it's not connected.
Matt Adams
Electrical Engineer Major
York College of PA
Chevy Cavy Rally Sport
KarTuneMan
Platinum - Posts: 7,056
Posted: April 08, 2005 at 5:56 PM / IP Logged
the trunk release wire is a neg(-) output
the p1 connector, grey wire, use a relay
