2005 Dodge Wiring Diagrams
nathanstl
Posted: April 07, 2005 at 8:15 PM / IP Logged
I need the wiring diagrams for any 2005 Dodge vehicles. I'm starting to do back up sensors, dvd's, and navigation installs on new dodge vehicles. Thanks guys!
thepencil
Gold - Posts: 1,526
Posted: April 09, 2005 at 6:13 PM / IP Logged
Any is too broad. A specific one I might be able to help you.
Be careful whose advice you buy, but be patient with those who supply it.2005 Dodge Wiring Diagrams - Last Post -- posted image.
nathanstl
Posted: April 10, 2005 at 12:44 PM / IP Logged
2005 Grand Caravan w/ rear air. Also Magnum. Thanks!
thepencil
Gold - Posts: 1,526
Posted: April 10, 2005 at 9:05 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / CARAVAN / 2005 / Remote Start
[PRINT THIS PAGE]
12volts lt. blue/red (10A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter PURPLE / brown   -   ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignition pink/white   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green   -   BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed 456L interface modules.
Power Unlock same as power lock wire
Lock Motor tan/white   5wi BCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green   5wi BCM, green plug, pin 28
Parking Lights+ WHITE/ brn (L), WHITE/ org (R)   +   driver kick, harness to rear
Parking Lights- WHITE/ brown   -   switch or BCM, gray plug, pin 21
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
Hazards WHITE/ dk. blue   -   switch or BCM, gray plug, pin 31
Turn Signal(L) wht/lt blu (F), wht/dk grn (R) +   BCM, green plug, pins 1, 2
Turn Signal(R) WHITE/ tan (F), WHITE/ brown (R) +   BCM, green plug, pins 3, 4
Reverse Light WHITE/ lt. green   +   BCM, green plug, pin 9
Door Trigger see notes   -   BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervision yellow/brown or yellow/white   +   BCM, white plug, pin 33
Trunk/Hatch Pin PURPLE / orange   -   BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue (export model) -   BCM, white plug, pin 30
Trunk/Hatch Release PURPLE / tan   -   BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
Power Sliding Door PURPLE / dk. blue   -   BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT BROWN / white   ac   ign coil pack or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake dk. GREEN / WHITE   -   parking brake switch
Horn Trigger dk. GREEN/ purple   -   steering column
Memory Seat 1 PURPLE / brown   -   BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2 same as memory seat 1 wire   -
Memory Seat 3 N/A   -
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 556C, 556U, or 555U
Notes: Standard on SXT models. Optional on SE models.
DIRECTWIRE™ WIRING INFORMATION - DODGE / MAGNUM / 2005 / Remote Start
[PRINT THIS PAGE]
12volts lt. blue/red (15A)   +   ignition harness
Starter pink/dk. green   +   ignition harness
Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Ignition
Third Ignition
Accessory same as second starter wire   -   ignition harness
Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory
Keysense
Power Lock PURPLE / dk. green   -   DKP or cluster, gry 26P plug, pin 5
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Lock Motor lt. green   5wi DKP or cluster, gry 26P plug, pin 12
Unlock Motor tan/lt. green   5wi DKP or cluster, gry 26P plug, pin 11
Parking Lights+ WHITE/ purple   +   pass. kick, brn 26 pin plug, pin 26
Parking Lights- WHITE/ brown   -   sw or cluster, gry 26P plug, pin 3
Notes: Parking lights are negative trigger thru an 1,670 ohm resistor. There is a rest resistance on the wire, so must use a relay to isolate from the switch.
Hazards WHITE/ dk. blue   -   hazard switch
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light WHITE/ lt. green   +   pass. kick, brn 26 pin plug, pin 17
Door Trigger see notes   -   each kick or instrument cluster
Notes: The LF door is purple in the white plug, pin 3. The RF door is PURPLE / white in the white plug, pin 3. The LR door is PURPLE / gray in the gray 26 pin plug, pin 10. The RR door is purple / YELLOW in the gray 26 pin plug, pin 9. Use all four wires and diode isolate each.
Dome Supervision yellow/white   +   instrument cluster, wht plug, pin 12
Notes: Also found in the passenger side A pillar.
Trunk/Hatch Pin PURPLE / orange   -   PKP or cluster, gry 26P plug, pin 23
Hood Pin PURPLE / lt. blue (export only)   -   pin switch under hood
Trunk/Hatch Release PURPLE / tan   -   PKP or cluster, gry 26P plug, pin 22
Notes: The hatch release is negative trigger thru a 4,700 ohm resistor. MUST use a relay. This wire will meter when you use the release handle on the rear hatch.
Power Sliding Door N/A
Tachometer NOT BROWN / yellow   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire dk. GREEN / WHITE   +   brake pedal switch
Parking Brake gray/black   -   sw or cluster, gry 26P plug, pin 18
Horn Trigger dk. GREEN/ orange   +   horns under hood
Memory Seat 1 PURPLE / brown   -   memory switch in driver door
Notes: Memory seats are negative trigger thru resistors. The resistor values are not known at this time. Cut the wire and meter the values as you press the memory 1 and memory 2 buttons.
Memory Seat 2 same wire as memory seat 1   -
Memory Seat 3 N/A   -
Notes: Standard on all models.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
