audiovox remote programming
almeida79
Member - Posts: 47
Posted: April 09, 2005 at 2:58 PM / IP Logged
Hello I was wondering if anyone here has the transmitter programming instructions for the audiovox  PRO9675FT4 remote start alarm combo.I looked both in the installation and owners manual but neither one has the transmitter programming info.Thank's Jay
Jay
swamprat323
Gold - Posts: 1,335
Posted: April 09, 2005 at 3:36 PM / IP Logged
i did not see it either, i aslo look through 15 others audiovox manurals did not see it in ANY of them, give audiovox a call and ask them
Chris Luongo
Platinum - Posts: 3,746
Posted: April 10, 2005 at 8:20 PM / IP Logged
The programming manual is a separate paper.
Programming goes like this:
1. Key on.
2. Tap valet switch three times; hear one short chirp....you are about to program channel 1...which is lock.
3. Press lock on the new transmitter; you'll hear a long, loud chirp.
4. Tap valet switch three times....two short chirps which is channel two....which is unlock.....push unlock and hear long, loud chirp..............
4. Keep on going just like that..... channel three is the green RS button........ channel four is the gray Option button.
P.S. The unit only holds four remotes........... if you want to "kick out" any lost or stolen remotes, just "fill" all four "slots" with the remote(s) you have now.......... for example, if you press "lock" four times during programming with your new remote, you'll fill up all four slots, and any other remotes will no longer work.
rdesai
Posted: April 11, 2005 at 10:46 AM / IP Logged
Can you tell me programming steps for an aps995a. I just got a truck and it didnt come with a remote.
