starter kill
paradox_108
Member - Posts: 48
Posted: April 18, 2005 at 7:47 PM / IP Logged
where is the best place to cut the starter cable? inside the steering column or behind the fuse pannel?
and do you guys run extra cable to the relay to keep it hidden somewhere?
thanks for any advice.
mo12v
Posted: April 18, 2005 at 8:57 PM / IP Logged
Your pick.............STEALTH is the name of the Game for Alarm Systems
MO
cgalvin29
Member - Posts: 35
Posted: April 19, 2005 at 2:08 AM / IP Logged
im not a big fan of starter kills i just dont luike that fact that the 70,000 dollar car i just put an alarm in is erlying on a $0.69 relay to start up. depending on the vehicle if its a 98 or newer gm or a vehicle with a transponder, i wouldnt worry about a starter kill if somebody is talented enough to steal a car with these factory imobilizers in place they will be able to bypass a starter kill, but hey it just my .02
thepencil
Gold - Posts: 1,526
Posted: April 19, 2005 at 8:22 AM / IP Logged
I agree with above post. I don't put on starter kill any more for vechile with immobilizer unless requested. From experience the cut wire behind the fuse panal has to be the most painful for me when looking for the starter kill relay wire.
Be careful whose advice you buy, but be patient with those who supply it.starter kill - Last Post -- posted image.
