Need amplifier advice
racer427
Silver - Posts: 381
Posted: April 20, 2005 at 5:29 PM / IP Logged
The sub portion of the amp is seperate from the rest of it. You can run your mains at 4ohms and your sub at 2ohms.
 Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
jdog0411
Copper - Posts: 150
Posted: April 20, 2005 at 5:32 PM / IP Logged
Ok, good......that may just be the amp I'm looking for then. Thanks for the recommendation!
2004 BMW 325ci.
Alpine CDA-9885
JL 300/4 and 250/1
JL XR 5.25 comps
Infinity Kappa Perfect 12
racer427
Silver - Posts: 381
Posted: April 20, 2005 at 5:35 PM / IP Logged
Not a problem, if you have a local Kicker dealer close to you, I would go check it out first, just to make sure that it is the right amp for your application and I know that it is a pretty big amp as well.
 Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
