12 volt source
Blacktj
Member - Posts: 12
Posted: April 20, 2005 at 10:53 PM / IP Logged
Hello,
I'm about to connect a piezo siren on my Clifford Concept 600, got all the wiring layout figured out, just need 2 last pieces of info.  Just want to make sure I do this right and not mess anything up!
1- Should I use the egnition wire for my 12+Volt constant source, or should I tap into the radio cable or go direct to the battery?  The battery direct is probably the less desirable option for security purposes I assume.
2- On the wire that goes from my relay's 30&86 pins that will go into my 12+Volt constant source, the diagram on this website says "Fused 12+".  How big of a use should I use for a typical piezo?  I don't have the exact specs for mine, but it looks identical to one that uses 250mA.
Thanks,
Tony.
Bmnicolosi
Copper - Posts: 173
Posted: April 22, 2005 at 10:14 AM / IP Logged
connect to the constant power wire at the ignition harness and put in a 15 amp fuse
If you say "I already know how", don't ask me a single question.
Captanham
Silver - Posts: 365
Posted: April 22, 2005 at 1:03 PM / IP Logged
use the ignition, the radio would not be a good choice, i would just tap it in behind the fuse for your alarm and then you dont' need another fuse
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
nava94
Silver - Posts: 296
Posted: April 23, 2005 at 5:10 PM / IP Logged
get it at the ignition harness and use a fuse.
