2005 Avalanche 529T problems
1rstClassSC
Member - Posts: 21
Posted: May 12, 2005 at 1:04 AM / IP Logged
I just installed 2 529T's on a 2005 Avalanche. But only the two rear windows work. The two front windows are a diffrent wireing system I think. When I test the rear window module up wire, it rests at (-) and when I activate it it sends a (+) signal for the windows to go up. Now, the two front windows rest at (+) and when hit the up button they then rest at (-). How do I wire up these front switches. I called my distributor and they told me that i needed to add one relay to each door to send a (-) input to each door module. I followed their instructions and I got nowhere. Can someone please instruct me on how to wire up these two front doors?
Thank You,
Luis
extreme1
Silver - Posts: 1,070
Posted: May 12, 2005 at 9:35 AM / IP Logged
as I always recommend, go directly to the motor wires.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
1rstClassSC
Member - Posts: 21
Posted: May 12, 2005 at 9:57 AM / IP Logged
I did run seprate wires to each door. Its just that the two front door modules have a diffrent lock system than the two rear doors. I think its a type C door lock system.
Luis
mo12v
Posted: May 12, 2005 at 12:16 PM / IP Logged
<<< I think its a type C door lock system >>>
U asked about Window Roll Up...........The Door Lock System, other than DATA LINK, has nothing to do with Window Roll UP
You need to wire your Windows as Reversal Rest at Ground.
Window UpD\ BLUE P\ BLUE
Dr Rear\BLUE
Ps Rear\BLUE @ Each Switch Due to Data Link
Window DownDF/ BROWN  PF/ BROWN DR/BROWN  PR/BROWN
MO
1rstClassSC
Member - Posts: 21
Posted: May 12, 2005 at 10:49 PM / IP Logged
sorry I meant to say Type C Window System. Right now I have the switch and motor wires going to each side of the cut Blue thick wire in the window switch. How exactly do I wire them as Reversal rest at ground. Do I need relays? Do you have a link to a diagram?
Luis
1rstClassSC
Member - Posts: 21
Posted: May 14, 2005 at 2:53 AM / IP Logged
Anyone? I need a diagram on how to relay a Type C Window System.
Luis.
1rstClassSC
Member - Posts: 21
Posted: May 15, 2005 at 1:35 AM / IP Logged
Help Please!!!!!!!!
Uniqueauto
Copper - Posts: 73
Posted: May 18, 2005 at 11:58 PM / IP Logged
Are you testing the correct wires? I just did a 2005 tahoe and had no problems.
Installer/Owner
Double check twice Install once!
Wires are my Best Friends
