Magicar FAI-300 help
QuagmireMan
Member - Posts: 25
Posted: November 18, 2002 at 6:55 PM / IP Logged
i can't find much info on this  alarm i just bought, any would help. thanks
QuagmireMan
Member - Posts: 25
Posted: November 18, 2002 at 6:59 PM / IP Logged
p.s i have a 93 s-10 ex cab and i was wondering if anyone new the best place to mount the alarm unit and the bes placeto find all the wires, you know hints and such
thanks again
   Chris
alarmpro
Copper - Posts: 110
Posted: November 18, 2002 at 8:46 PM / IP Logged
really cheap brand!  But works great!!!!
Probable manufacturing problem= won't auto arm, and won't lock the doors with ignition, but will unlock w/ignition ....
Other then those two problems, its a good alarm,
O Sorry I forgot== Crappy motion sensor, really old style not electronic, spring action activation
O and I just remembered after arming there is a 10 second delay for the motion sensor to work and worst of all a 30 delay for the doors to activate it= meaning its really not armed door wise untile after 30 seconds.
Besides those things its a really good alarm, for the money.  I use to get them for $25 and charge $99 including installation!!!
S-10 PICKUP 1993
WIRE COLOR LOCATION
12 VOLTS CONSTANT RED IGN HARNESS
IGNITION 1 PINK IGN HARNESS
IGNITION 2
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 ORG IGN HARNESS
ACCESSORY /HEATER BLOWER 2
STARTER YEL IGN HARNESS
PARKING LIGHTS BRN (+) HEADLIGHT SWITCH
DOMELIGHT WHT/BLK (-) AT DRV PIN SWITCH
PWR DOOR LOCK L BLU DRV KICK PANEL
PWR DOOR UNLOCK BLK DRV KICK PANEL TYPE C
TRUNK RELEASE
TACH SENSOR WHT AT DIST
BRAKE WHT(+) AT SWITCH ABOVE BRAKE PEDAL
HORN BLK(-) STEER COLM HARNESS
FACTORY DISARM N/A
QuagmireMan
Member - Posts: 25
Posted: November 19, 2002 at 4:48 AM / IP Logged
thanks, and their was a little spring device that came with it, what is it?
QuagmireMan
Member - Posts: 25
Posted: November 19, 2002 at 12:52 PM / IP Logged
am i going to need a relay for my door locks?
alarmpro
Copper - Posts: 110
Posted: November 19, 2002 at 4:33 PM / IP Logged
the spring thing is the shock sensor.  I would advise that you purchase an electronic shock sensor for the simple fact that you will not be able to park your vehicle up or down a steep hill because the wight of the spring will activate the motion sensor because its a spring and an electronic sensor does not have that prob.
you need two relays its reversal rest at ground type.
here is the wiring diagram....
Magicar FAI-300 help - Last Post -- posted image.
QuagmireMan
Member - Posts: 25
Posted: November 19, 2002 at 5:41 PM / IP Logged
ok thanks, but i dont think its the shock censore, its more of a rod
QuagmireMan
Member - Posts: 25
Posted: November 19, 2002 at 5:42 PM / IP Logged
p.s. where can i get a better shock censore?
alarmpro
Copper - Posts: 110
Posted: November 19, 2002 at 6:01 PM / IP Logged
http://www.velocitymotorsport.com
Don't know what the rod is???
if you really want a great sensor then go for the radar sensor.
I have it on my personal car and if someone even looks inside through the window , the sensor sets off the alarm
