Voltage Guage During Remote Start
Need 2 b lower
Member - Posts: 29
Posted: June 05, 2005 at 11:16 PM / IP Logged
I installed a viper 791xv on my ranger, and everything works fine. but when i remote start it, the voltage guage stays around 10 or 11 volts, then when i put my key in and deactivate it, it gos right up to 14 volts. The check engine light that comes on when the key is turned to acc, also satys on until the remote start is deactivated. Any ideas and help is appreciated. Thanks!
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 9:03 AM / IP Logged
What year and model is your vehicle? Check and ensure that you have proper ground point on your alarm unit.
Be careful whose advice you buy, but be patient with those who supply it.Voltage Guage During Remote Start - Last Post -- posted image.
hagmanti
Silver - Posts: 304
Posted: June 06, 2005 at 10:12 AM / IP Logged
It sounds to me like there's an acc/ign wire not hooked up, which is only getting power through some sort of back feed....
Me
joe_1
Silver - Posts: 286
Posted: June 06, 2005 at 12:50 PM / IP Logged
same here could be a acc or ign wire supply problem check all connections, the check light is coming on  because it is detecting the engine running but there is no supply coming back from a sensor or something due to a wire getting no supply from remote start but when the key is on it is making the correct supply to all ign acc wires.
let me know how it goes
Need 2 b lower
Member - Posts: 29
Posted: June 06, 2005 at 1:29 PM / IP Logged
ill recheck aall of my wires. thanks for your help guys. its a 1993 ford ranger. i used the diagram off here so im sure the wires are in the right place, and i soldiered all my connections, but i will double check.
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 2:51 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / RANGER / 1993 / Remote Start
12volts yellow    +   ignition harness
Starter RED / lt. blue    +   ignition harness
Second Starter
Ignition RED / lt. green    +   ignition harness
Second Ignition
Third Ignition
Accessory gray / YELLOW    +   ignition harness
Second Accessory
Keysense
Power Lock pink / YELLOW   5wi drivers kick panel
Power Unlock pink/green   5wi drivers kick panel
Lock Motor
Unlock Motor
Parking Lights+ brown      at switch or fuse box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ lt. blue    +   under dash light, dkp
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gray/orange   AC   ECM or ign. module
Notes: The ignition module is located just in front of the battery. The ECM is located in the passenger kick panel. The 2.3 DIS module is located on top of the motor just behind the alternator.
Wait to start
Brake Wire lt. green    +   at brake pedal switch
Parking Brake
Horn Trigger yel/lt. grn or blue      steering column
Notes: The yellow/lt. green is found negative (-) on models with factory cruise control and the blue is found positive (+) on models without factory cruise control.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Need 2 b lower
Member - Posts: 29
Posted: June 19, 2005 at 1:41 AM / IP Logged
due to a shhhty diagram i used before (forget where i got it from), the wiring was causing this. i used the one provided by this site and thepencil and it works great. Thanks guys!
