wiring amp to subs ?
mick328
Posted: June 15, 2005 at 4:57 AM / IP Logged
if i bridge my 2 channel amp , how do i wire my twin vibe subs they are cbr120 ?
longmill pharaoh ra-003
vibe cbr 120 twin enclosure
do i wire them in series or paralell ?
stevdart
Platinum - Posts: 5,816
Posted: June 15, 2005 at 8:47 AM / IP Logged
Here is a wiring wizard:  http://www.sounddomain.com/shop/wooferwizard.pl
Enter the number of subs and the voice coil configurations.  You want to end up with an impedance of 4 ohms or higher to bridge across a two channel amp.
mick328
Posted: June 16, 2005 at 6:23 AM / IP Logged
so i need to wire them in series to my bridged amp?
As far as i understand my speakers are 4ohm single voice and i have to end up with 4 ohms so i wire them in series?
That is amp+ to + then - to other speaker + then - back to amp-
I hope that is right please let me know as i am installing today.
thanks, (i know i might sound daft but it aint easy)
stevdart
Posted: June 16, 2005 at 11:09 AM / IP Logged
That is correct.  It will be an 8 ohm bridged load.  Your amp will most likely be capable of twice the power output with a 4 ohm bridged load, but with two SVC 4 ohm subs that is the only choice you have.  (Or you can connect a sub per channel if you like for the same output.)
