Compustar and 530T
2000civic
Member - Posts: 15
Posted: June 23, 2005 at 11:53 PM / IP Logged
I am going to be installing a DEI 530T window system along with my Compustar 2WASS alarm.  Does anyone have any hints about which wires need to be hooked up to eachother?  It is in a 2000 Honda Civic and I know that window wires, but was confused on the rest of the install.  Any help would be much appreciated.  Thanks
Powermyster
Silver - Posts: 962
Posted: June 24, 2005 at 5:59 AM / IP Logged
i just done a 200 civic last night.
what wires are you confused on.
I have to try the lockign again because i couldn't get it to work on my one but i got everything else.
hawn13
Copper - Posts: 171
Posted: June 24, 2005 at 8:49 PM / IP Logged
if you are having a problem with window roll up you can try hooking it to lock wire  and changing pulse duration to 2.5 the other a better option is to get a pulse time relay. or you can hook it to aux 2 the only draw back is you have to keep pushing the button to roll the window up. hope this answers your ?
