97 honda odyssey power lock diagram needed
unclesam
Posted: July 08, 2005 at 3:26 PM / IP Logged
can anyone give me the diagram or where is this power lock control module located. better with the pictures. I am trying to install a alarm and don't know where is the relays for this .
thanks
sam
thepencil
Gold - Posts: 1,526
Posted: July 08, 2005 at 3:31 PM / IP Logged
Sorry, I don't have a picture to show you.
Power Lock BLACK/ white    -   4 pin gray plug above
Power Unlock orange    -    fusebox in blue tape
DIRECTWIRE™ WIRING INFORMATION - HONDA / ODYSSEY / 1997 / Security
12volts white    +   ignition harness
Starter BLACK/ white    +   ignition harness
Ignition BLACK / YELLOW    +   ignition harness
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ RED / black      fusebox or left st col
Notes: There is a stack of five plugs to the left of the steering column. The park light wire is located in the lowest plug on the top left corner, trunk pin is in one of the upper plugs. The door trigger is on the right side of the steering column in a 16 pin plug like the 95 Accord. Plug is mounted higher but unclips so you can access the harness more easily. Trunk trigger is in a green 18 pin plug above fusebox.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger WHITE/ black    -   16 pin right of st col
Dome Supervision
Trunk/Hatch Pin ORANGE / green    -   left of st. column
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue    AC at distributor
Horn Trigger gray to lt. GREEN/ blue    -   rt st col at relay
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.97 honda odyssey power lock diagram needed - Last Post -- posted image.
