Security Wiring, 2005 Mariner and 05 sable
Dcstyles
Posted: July 26, 2005 at 11:09 PM / IP Logged
Hi ,
I was wondering if i can get some help with some wiring information on a 2005 Mariner and 05 sable
griselda
Member - Posts: 41
Posted: July 26, 2005 at 11:18 PM / IP Logged
www.designtech-intl.com
maybe that help you
djram19@yahoo.com
thepencil
Gold - Posts: 1,526
Posted: July 28, 2005 at 9:37 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MERCURY / SABLE / 2005 / Remote Start
12volts lt. GREEN/ purple (40A)   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Second Starter N/A
Ignition RED / lt. green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW   +   ignition harness
Second Accessory BLACK/ lt. green   +   ignition harness
Keysense BLACK/ pink   -   ign harn or GEM, 20 pin plug, pin 17
Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom.
Power Lock pink / YELLOW   -   GEM, 26 pin plug, pin 18
Power Unlock pink/lt. green   -   GEM, 26 pin plug, pin 6
Lock Motor pink/black   5wi SJB, top plug, pin 3
Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses.
Unlock Motor RED / white   5wi SJB, top plug, pin 2
Parking Lights+ brown   +   switch or SJB, bottom plug, pin 31
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +   steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +   steering column
Reverse Light BLACK/ pink   +   kick panel, harness to rear
Door Trigger see notes   -   GEM, 26 pin plug
Notes: The LF door trigger is yellow/black in pin 5. The RF door trigger is gray/red in pin 19. The LR door trigger is lt. GREEN/ YELLOW in pin 20. The RR door trigger is pink/lt. blue in pin 7. Use all four wires and diode isolate each.
Dome Supervision BLACK/ lt. blue   +   SJB, top plug, pin 22
Trunk/Hatch Pin see notes   -   see notes
Notes: On the sedans use BLACK/ pink at the light in the trunk. On the wagons use WHITE/ purple at the GEM, 26 pin plug, pin 21.
Hood Pin tan/lt. green   -   GEM, 26 pin plug, pin 17
Trunk/Hatch Release purple / YELLOW   -   GEM, 26 pin plug, pin 3
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm pink/white   -   GEM, 26 pin plug, pin 4
Disarm No Unlock see factory alarm disarm
Tachometer NOT red   ac   ign coil/coil pack or fuel injector
Wait to start N/A
Brake Wire RED / lt. green   +   brake pedal switch
Parking Brake lt. green   -   switch or GEM, 26 pin plug, pin 1
Horn Trigger dk. blue   -   column or SJB, bottom plug, pin 1
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes:
DIRECTWIRE™ WIRING INFORMATION - MERCURY / MARINER / 2005 / Remote Start
12volts red (10A)   +   ignition harness
Starter tan/lt. blue   +   ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Second Accessory N/A
Keysense BLACK/ pink   +   ign. harn. or SJB, conn. E, pin 29
Notes: The SJB (Smart Junction Box) is the fuse/relay box on the passenger side of the center console.
Power Lock pink/white   -   driver kick or SJB, conn. D, pin 22
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor pink/black   5wi driver kick or SJB, conn. C, pin 20
Unlock Motor RED / orange   5wi driver kick or SJB, conn. C, pin 3
Parking Lights+ brown   +   driver kick or SJB, conn. C, pin 19
Parking Lights- WHITE/ black   -   switch or SJB, conn. E, pin 4
Hazards RED / white   -   switch or SJB, conn. E, pin 5
Turn Signal(L) lt grn/wht (F), lt grn/wht (R) +   SJB, conn B, pin 14 & conn C, pin 6
Turn Signal(R) wht/lt blu (F), wht/lt blu (R) +   SJB, conn B, pin 23 & conn C, pin 9
Reverse Light BLACK/ pink   +   driver kick or SJB, conn. C, pin 10
Door Trigger use dome supervision wire
Dome Supervision pink   -   driver kick or SJB, conn. C, pin 28
Trunk/Hatch Pin use dome supervision wire
Hood Pin PURPLE / orange   -   pin switch or SJB, conn. B, pin 5
Trunk/Hatch Release N/A
Factory Alarm Arm WHITE/ purple   -   driver kick or SJB, conn. D, pin 2
This wire will also lock the doors.
Factory Alarm Disarm dk. blue/lt. green   -   driver kick or SJB, conn. D, pin 3
Tachometer NOT red or WHITE/ red (Hybrid)   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green   +   switch or SJB, conn. C, pin 14
Parking Brake lt. GREEN/ red   -   switch or SJB, conn. D, pin 13
Horn Trigger yellow/lt. green   -   column or SJB, conn. A, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
SecuriLock
Part #: 556UW
Alternate Part1 #: 555U
Notes:
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.Security Wiring, 2005 Mariner and 05 sable - Last Post -- posted image.
