wiring four 4 ohm SVC to 2 ch amp?
rocafella1
Posted: August 06, 2005 at 4:07 PM / IP Logged
i am running 4 12 inch single voice coil (4 ohm) sub woofers in a sealed box on a 2 channel amplifier the amp is 2 ohm stable do anyone know of a way to wire the woofers at 2 ohm load and not 4 ohm or a way to get the most power out of my amp the amp is a interfire 2950c it is a 1000 watts 550 watts rms help please
if its not broke dont fix it
william
stevdart
Platinum - Posts: 5,816
Posted: August 06, 2005 at 4:16 PM / IP Logged
Sure.  That amp is stable at 2 ohms per channel, and stable at 4 ohms with a bridged load.  Wire your four subs so that you come to a final 4 ohm impedance and bridge across the channels.  The amp will output its most power into a 4 ohm bridged load, which is 550 watts RMS / 1000 watts peak.
Wire two of the subs in series, and the other two in series.  Then connect the pairs in parallel for 4 ohms.
wiring four 4 ohm SVC to  2 ch amp? - Last Post -- posted image.
rocafella1
Posted: August 06, 2005 at 5:37 PM / IP Logged
right now i have them ran parallel into each channel how many ohms is the amp running i was wondering i s there to get it down to 2 ohms
william
haemphyst
Platinum - Posts: 5,059
Posted: August 06, 2005 at 6:11 PM / IP Logged
The diagram above WILL give you 2 ohms - PER CHANNEL (if bridged).
If your amp is not bridgeable, then use this diagram...
