97 cavalier diagram
nhaze
Member - Posts: 6
Posted: August 07, 2005 at 8:35 PM / IP Logged
hi    i got a comando alarm with remote start i want to install on my 97 cavalier. i was wondering if anybody has a wire diagram for this vehicle.
thanks for the help
              haze
mo12v
Posted: August 07, 2005 at 8:41 PM / IP Logged
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightL GREEN/ BLACK (DR) &L BLUE (ALL DOORS) AT CONV. CENTER *
Trunk Pin SwitchN/A
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockL BLUEDRIVER KICK (W/O OEM KEYLESS) **
Power UnlockWHITEPANEL (W/OEM KEYLESS)**
* L GREEN/ BLACK (-) Covers Driver Door Only. L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. Convenience Center Module Located Above Passenger Kick Panel.
** Without OEM Keyless Door Lock Wires MUST Be Tested From PASSENGER Switch!!
W/O OEM Keyless ..... Reversal Rest At Ground Door Locks.
With OEM Keyless ..... Positive Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseBLACK/ WHITE (+)AT OEM KEYLESS MODULE *
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsD BLUE (-) (LO) &PINK (-) (HI) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit
. * With OEM Keyless Only!! OEM Keyless Module Located On Drivers Side Of Trunk.
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE **
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGNITION SW. HARNESS (PCM & CLUSTER)*
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT SWITCH ON TRANSAXLE
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE or ORANGE At PCM Or Ignition Control Module. Both Wires Are 2 Cylinder Signals Each. PCM On Both Located In Passenger Front Fender. Ignition Control Module On 2.2L Located On Rear Center Of Engine. ** WHITE Wire Powers Powertrain Control Module (PCM) & Instrument Cluster.
G.M. Passlock Diagram.
MO
nhaze
Member - Posts: 6
Posted: August 07, 2005 at 10:14 PM / IP Logged
thanx mo your a blessing from god.  i was starting to pull my hair out by the roots.  with this diagram i'll be able to do my task at hand.   again thanx and god bless
thanks for the help
              haze
