Viper 791XV horn trigger?
jesussalvdr
Member - Posts: 10
Posted: August 08, 2005 at 12:56 PM / IP Logged
High, I have a 1994 Nissan Altima SE. I have installed a viper 791XV security system on the car. My question is that I would like to change to siren for the factory horn to chirp. The problem is that the 791XV doesn't have a (-) horn trigger, or atleast i can't find it. All it has is the (+) siren output. Any help?
hey dude
jesussalvdr
Member - Posts: 10
Posted: August 08, 2005 at 2:07 PM / IP Logged
any input guys?
hey dude
chungo
Copper - Posts: 135
Posted: August 08, 2005 at 4:17 PM / IP Logged
you can change the sire output
alpine0000
Copper - Posts: 160
Posted: August 08, 2005 at 4:18 PM / IP Logged
i take it you arent familair with relays? this is a simple task to change the + siren output on the 791XV to a - output using a relay.
if you arent familair, here you go (this is assuming your factory horn needs a negative trigger input);
pin 85 - hook this to the + siren output from 791XV
pin 86 - ground this terminal
pin 30 - this is your negative output that you will hook up to the factory horn
pin 87 - ground this terminal
chungo
Copper - Posts: 135
Posted: August 08, 2005 at 4:29 PM / IP Logged
but dont forget to change the siren output to a pulsed output
alpine0000
Copper - Posts: 160
Posted: August 08, 2005 at 4:33 PM / IP Logged
yes, i forgot to add that in my post. good eye!
jesussalvdr
Member - Posts: 10
Posted: August 08, 2005 at 5:46 PM / IP Logged
yes, I already changed the siren output to pulsed setting. Thanks guys for all of your help.
hey dude
