04 Civic Firewall Access Point
bewaffnet
Posted: August 20, 2005 at 9:35 AM / IP Logged
I am routing a power wire for an amp in the trunk. I was wondering if anyone had a suggestion for a location to route the power wire through the firewall and into the interior. I want to choose a good location if I actually have to make a new hole! Thanks.
skoldspuppy
Silver - Posts: 342
Posted: August 20, 2005 at 10:41 AM / IP Logged
I have a 2004 Civic sedan, I had to make a new hole right behind the glove box, take out the glove box  and you notice that you will be able to see the firewall right under the main wire harness and the lower AC vent
Also check out http://www.7thgencivic.com/forums/
it has everything you need for your civic in cluding many DYI's with loads of pictures, just use the search engine
Good Luck
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
