Starter disable on Ranger
jumargibbs
Member - Posts: 24
Posted: September 11, 2005 at 10:31 PM / IP Logged
My alarm module has an onboard relay for the starter disable. The instructions state to cut the starter wire (RED / lt. blue- '88 Ford Ranger) to add this relay to the circuit. However, there are two RED / light blue wires at the ignition switch. Does it matter which one I cut? Are they both part of the same circuit?
Thanks in advance.
Ken
mo12v
Posted: September 11, 2005 at 10:39 PM / IP Logged
Double check that other wire..............
Also, use a Meter to check your Starter wire before you cut.......
MO
