'00 Grand Prix factory Keyless entry
BigBurbMan
Member - Posts: 20
Posted: October 05, 2005 at 9:11 AM / IP Logged
I just bought this car and the factory keyless remotes don't work.  No aftermarket alarm or anything installed.  I bought programming instructions off of eBay, but still no go.  New batteries in the remotes.  Where do I go from here?  Not to the dealer I hope....
How do I check the car-side receiver?  Thanks for any info!
redpeppers
Silver - Posts: 483
Posted: October 05, 2005 at 12:03 PM / IP Logged
go to local car audio and security shop and buy a new keyless entry system.....
Where theres is a wire there's a way.
mo12v
Posted: October 05, 2005 at 1:32 PM / IP Logged
Have you verified from the Build Sheet or Dealer that your car has Factory Keyless / Alarm??  Usually, the dealer can run your VIN number & tell you.  A lot of times Remotes are put in a vehicle at Auction or sale to make it look like it has Keyless..........
MO
BigBurbMan
Member - Posts: 20
Posted: October 05, 2005 at 1:39 PM / IP Logged
Crap, I never thought of that.....but, I bought the car from original owner (according to CarFax), plus it has a bunch of other options like auto climate control, etc., so unlikely it doesn't have keyless.
mo12v
Posted: October 05, 2005 at 1:48 PM / IP Logged
If it's loaded...you are probably right........
Have you tried ............DRIVERS SIDE:>>>>Roll down your window, ......Lock the Drivers door at the Panel Switch, Close door & wait approx 45 seconds.........Put your hand inside & Unlock Door with Slide Latch........Open Door & see if the Alarm triggers??  Turn Door Key Switch to turn off
MO
mo12v
Posted: October 05, 2005 at 3:21 PM / IP Logged
When you tried progamming, did you hear the Confirmation Chime??
MO
