Viper 591XV Turn Signal
lexelite
Copper - Posts: 82
Posted: October 18, 2005 at 8:10 AM / IP Logged
Wanted to know if there is anyway to Flash the Turn Signals (2 Channels, Pos) on the Viper 591XV w/o the use of relays?
Confirmation Flash for lock/unlock
In case you want to know, its for LED mirrors :)
mrcllusb
Copper - Posts: 489
Posted: October 18, 2005 at 9:09 AM / IP Logged
You should be able to take the wire that normally go to the parking light circuit,and tap into the relay that controls ur 4 way flashers..
"ole blake"
ringojam
Copper - Posts: 215
Posted: October 18, 2005 at 3:55 PM / IP Logged
Use 2 diodes from park light and pick up at the hazzard switch.Meaning split the park light with 2 diodes and run one to the left turn and the other to the right turn signal wires at the hazzard switch
lexelite
Copper - Posts: 82
Posted: October 18, 2005 at 4:46 PM / IP Logged
The car only has one relay for both Turn Signals and Hazard Flashers. Not sure how to affect one without the other there.
Is is possible to tap the Hazard Switch instead?
lexelite
Copper - Posts: 82
Posted: October 18, 2005 at 4:52 PM / IP Logged
Do you have a diagram for the Toyota Hazard Switch?
If I read you correctly, you split the wire into a Y- Config then apply a diode after the switch on both sodes.
Right?
lexelite
Copper - Posts: 82
Posted: October 18, 2005 at 5:38 PM / IP Logged
Figured out the wiring, but activation on both sides are +
Does the 591XV pulse a Pos or Neg confirmation signal? If neg, should I use a relay to convert.
Viper 591XV Turn Signal - Last Post -- posted image.
