250watt to rms
h@z3
Member - Posts: 15
Posted: October 27, 2005 at 9:39 PM / IP Logged
i just bought a pair of 6"x9"s and they are 250watt i was just wondering how i can figure out the output power in rms if you need to know more about them to work it out just ask and ill get back to u with the details thanx alot
Alpine Guy
Platinum - Posts: 2,478
Posted: October 27, 2005 at 9:51 PM / IP Logged
What kind and model speakers are they?
geepherder
Platinum - Posts: 3,668
Posted: October 27, 2005 at 9:54 PM / IP Logged
I'm guessing that your speakers have a peak rating of 250 watts a piece, right?  And you'd like to know the rms rating?  The best thing would be to contact the manufacturer, but generally speaking, a speaker's rms rating is usually about half it's peak power rating.
h@z3
Member - Posts: 15
Just a cheap set of rampage 6"x9" 3 ways there 250watt and the model is RMP6932
h@z3
Member - Posts: 15
Posted: October 27, 2005 at 9:58 PM / IP Logged
kool thanks heaps geepherder so its usualy just half of the peak power?
DYohn
Platinum - Posts: 10,741
Posted: October 27, 2005 at 10:01 PM / IP Logged
Rampage (Audiovox) like a number of other low-end brands lists very misleading "ratings."  That "250 watts" means the PAIR together will supposedly handle a total of 250 watts PEAK (or for about 1/2 second) or 125 watts PEAK per speaker.  The actual power rating per speaker is probably much closer to 25 watts.  Do not expect much from those, or for them to last very long.
stevdart
Platinum - Posts: 5,816
Posted: October 27, 2005 at 10:03 PM / IP Logged
Not in this case, unfortunately.  Power handling numbers are whatever the maker decides will sell best in that particular market...and the cheapo market uses BIG numbers that mean virtually nothing.  If YOU classify them as cheap, and if they actually ARE cheap, then they're CHEAP and won't be capable of producing 125 watts of clean sound.  Figure on 40 or 50 maybe and be done with it.
h@z3
Member - Posts: 15
Posted: October 27, 2005 at 10:07 PM / IP Logged
ok then thanx heaps guys
