Tx learn program clifford Matrix RSX 3.2
bosdmeg
Posted: November 05, 2005 at 6:22 PM / IP Logged
Hello,
I have seen lots of good things on the12volt.com. This issue has me stumped. Maybe you can help. I have two Clifford Matrix RSX 3.2s one in my SUV and one in my wife's car. I have had absolutely no trouble with either unit until now. I want to be able to unlock and lock her car with my transmitter. So I used the directions in the install manual. Sitting in her car with my remote I:
1.     Open a door
2.     Turn on the ignition
3.     Select the function and hold the program / valet button (the siren chirps the appropriate number of times)
4.     Press the transmitter button (the siren chirps and my SUV locks)
5.     Exit by turning off the ignition
The unit should be programmed. But it isn't. I thought maybe I need to remove my transmitter code from the SUV. So I zapped the brain in the SUV with my Bitwriter. Then tried once more and got the same results.
So now I tried to reprogram the SUV with my transmitter following the same steps. And nada. Now I can't do any thing with my transmitter. Is there a step I'm missing? Has anyone else had an issue similar to this?
Learn to go down at WeBeDivin.com
bosdmeg
Posted: November 08, 2005 at 9:42 AM / IP Logged
OK I guess nobody knows? That's OK I found the answer else where. If you have a Clifford Matrix here is how you program a new clicker to it.
Follow the instructions in the manual:
1.     Open a door
4.     Press the transmitter button you want to program (the siren chirps)
This in not in the instructions.
5.     Press the Transmitter button you want to program AGIEN(the siren chirps)
Then return to the instructions in the manual.
6.     Exit by turning off the ignition
Tx learn program clifford Matrix RSX 3.2 - Last Post -- posted image.
Later
Bosdmeg
