Mach audio system
mchlzk
Posted: November 08, 2005 at 7:19 PM / IP Logged
I have checked the fuse under the hood that feeds the audio system, good.  Under the dash there are three fuses in the fuse box that are apparently for the audio system.  A 25A fuse that tests fine, a 5A fuse that tests 12V with the ignition on, and the third fuse is a 5A that i never have gotten anything out of.  I pulled the fuse and did a continuity check through it and it tests good.  As for any other fuses, there is not one on the amp next to the subwoofer, and I'm not sure if there are any more in line or not.  I need to find a diagram or another harness i guess.
Thanks for the help
~J
p.s.-You can go a long way with a smile and a gun
