which diode?
colaroaster
Copper - Posts: 53
Posted: November 24, 2005 at 5:29 PM / IP Logged
i'm wanting to install an autopage 650 plus in a 93 jeep cherokee. in my install manual, in order for me too use the hood pin switch with the alarm i must use a diode inline with the negitive safety wire and a diode inline with the alarm instant trigger. in the manual it doesn't list what diode, but earlier in the manaul it does list a diode (IN4003). my question is, do i use the IN4003 with the hood pin or another type?
mo12v
Posted: November 24, 2005 at 5:52 PM / IP Logged
Yep...........
The IN4003 Diode is pretty standard...........usually available @ Radio Shack
MO
kgerry
Platinum - Posts: 3,455
Posted: November 24, 2005 at 7:04 PM / IP Logged
1N4001 thru 1N4007   they are all the same 1 amp diode, only the voltage rating changes, and we only use them for 12 volts so buy whatever you can get cheaply.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
colaroaster
Copper - Posts: 53
Posted: November 24, 2005 at 8:22 PM / IP Logged
thanks for the help
