97 chevy astro van, remote start
trini18
Posted: November 27, 2005 at 5:10 PM / IP Logged
Hi I bought a bulldog remote starter and would like to know if anyone has installed this on their van?
I would like to know the wiring diagram for this van...I checked the wiring diagram founded on this site but when I went to hook it up...it was not working properly...so am not sure if the diagram is correct
I guess basicly what I need to know is the colours for the wires..
thanks
p.s. this site rocks97 chevy astro van, remote start - Last Post -- posted image.
mo12v
Posted: November 27, 2005 at 7:45 PM / IP Logged
You can get wiring off BULDog site also....  http://www.bulldogsecurity.com/
Here is what I have:
Good Luck
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightPURPLE (-)AT ANY PIN SWITCH *
Trunk Pin SwitchSAME CIRCUIT AS DOMELIGHT
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockL BLUE15 PIN CONNECTOR
Power UnlockWHITEIN DRIVER KICK PANEL
* PURPLE (-) Wire Also Located At Headlight Switch.
Positive Pulse Door Locks
Click Here For Our Databus & Immobilizer Bypass Cross Reference
Accessories
Window UpD\ D BLUE P\ L BLUE  @ MAIN SWITCH
Window DownR/ BROWN S/ TAN
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS *
Trunk ReleaseL GREEN (-)6 PIN CONN. IN PASS. KICK PANEL
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsYELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit.
* L GREEN (-) Wire Only Ground With Key In Ignition Switch And Driver Door Open
Negative Pulse Trunk Release
Remote Start
Tach SignalWHITEAT IGNITION COIL
Ignition #2ORANGEIGNITION SW. HARNESS (HEAT/AC)
Ignition #3WHITEIGN. SW. HARNESS (TRANS. MODULE) *
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRUCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT SWITCH ON TRANSAXLE
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* WHITE Wire Powers Transmission Module.
MO
