Soundstream PCA2000D
alexv305
Member - Posts: 28
Posted: November 30, 2005 at 2:16 PM / IP Logged
Yes I do I have a 235A alternator
Too make this short and simple. I am just trying to figure out how to calculate the amplifiers total rms output at 12 volts with its 75% efficientcy rating.. If you can demonstrate an equation that would be great
Alpine HU
Directed 5-Band Equalizer
Two Pionner 6x8 4-ways
Two Pionner 6x9 3-ways
Audiobahn A6004T
Two Kicker L5 15s
Audiobahn 1 Farad Power Cap
DYohn
Platinum - Posts: 10,741
Posted: November 30, 2005 at 2:20 PM / IP Logged
Sure.  Ohm's Law (see link to the left) is a basic fact everyone dealing with car audio should know by heart.  It states that Power (watts) = voltage times current flow.  So, if your fuse is rated at 150 amps, that would be the max the amp could draw before the fuse blows.  12V X 150a = 1800 watts.  This is the max on the INPUT side of the amplifier.  If it has 75% efficiency, the max it could possibly output is 1800 X 0.75 = 1350 watts. That would be MAX, by the way, not RMS.
alexv305
Member - Posts: 28
Posted: November 30, 2005 at 2:25 PM / IP Logged
The amp manual says 4000w peak power output and 2000w RMS @ 1 ohm mono if that helps any...
Alpine HU
Audiobahn A6004T
Two Kicker L5 15s
DYohn
Posted: November 30, 2005 at 2:35 PM / IP Logged
Well my friend, it's called Ohm's "LAW" because it is always true and you can't get around it.  For any amplifier to generate 4000 watts peak output using your 75% efficiency and 12 volt nominal numbers, would require an instantaneous current draw of 444.444 amps.  Might blow your 150 amp fuse, eh?  Also, to sustain 2KW RMS output would require about 222 amps continuous current draw.  Also toasts your fuse.  If the amplifier is really capable of that kind of output, which like I said I highly doubt, then you'll need to supply it appropriately.
Cheers.
alexv305
Member - Posts: 28
Posted: November 30, 2005 at 2:46 PM / IP Logged
Ok if an amplifier company rates their Class D amp at  2000w rms @ 1 ohm mono what would be its total real output in watts? Class D is 70% efficent so does this mean 2000 x 70% = 1400? So basically it only puts out a true 1400w rms?
Am I correct? I need help on making calculations.
Also if this is correct do all amp companies do this?
Alpine HU
Audiobahn A6004T
Two Kicker L5 15s
j_darling2007
Copper - Posts: 210
Posted: November 30, 2005 at 2:52 PM / IP Logged
No, if the amp is 70% efficient, this means that only 70% of the amperes fed into the amp is turned into the signal going to the sub.  The other 30% is converted to heat in the amplifier.
The amp companies rate the actual output (watts at x-amount of volts), so the efficiency has nothing to do with the wattage coming out of the amp.
There are 3 kinds of people in the world, those who can count and those who can't
DYohn
Posted: November 30, 2005 at 3:21 PM / IP Logged
Yes, exactly.  But
sort of contradicts itself in this way: the efficiency rating determines how much current the amp must draw in order to achieve the rated output.  This is limited by the physical capabilities of the components used in the amplifier, especially the current capacity of the power supply and power rails.  So if an amplifier is 70% efficient it must use larger components capable of higher current flow to generate its output than one that is, say, 80% efficient.
Just picking nits, I know.  Soundstream PCA2000D - Page 3 - Last Post -- posted image.
alexv305
Member - Posts: 28
Posted: December 01, 2005 at 7:38 AM / IP Logged
I am having trouble understanding the rule of decibels.
If I have a 2000w RMS subwoofer and I feed it 1000w RMS, then it wouldn't be a whole lot louder if I fed it 2000w RMS. It would only be +3dB louder. What about powering teo subwoofers? Both handle 750w RMS. Would they be almost as loud with only half the power?
Can someone explain this to me?
Alpine HU
Audiobahn A6004T
Two Kicker L5 15s
haemphyst
Platinum - Posts: 5,059
Posted: December 01, 2005 at 8:52 AM / IP Logged
wow... Alex, it seems that you have far too many questions than we can answer completely here. There are too many people offering advice to you. PLEASE check out the Basic Car Audio and Electronics website, and study it, know it, live it... VERY good website, with really helpful illustrations as well...
Page of 3
