2006 f350 powerstroke, remote start
drbill
Posted: December 02, 2005 at 8:40 PM / IP Logged
need help installing a viper 791xv. what is best way to wire wait to start input into remote start? Also need sorce forfactory wireing.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 02, 2005 at 9:37 PM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=6112&product=Remote%20Start
Wait to start is in the glow plug relay pack on the pass. side underhood firewall. GREEN / WHITE POS(+) while glow plugs are warming. Its a small silver amplifier looking box with 2 or 3 plugs in it.....look in the green plug
drbill
Posted: December 07, 2005 at 9:56 PM / IP Logged
Wait to start connection. Connected it with relay to green and white wire in green plug at the relay on side of motor. this wire shows voltage for much longer than light stays on. Truck attempts to start but wont when voltage goes to 0. Seems to wait to long. Any other suggestions for triger wire for wait to start.   thanks
KarTuneMan
Posted: December 07, 2005 at 10:39 PM / IP Logged
If you can set the "wait to start" for AT LEAST 30 seconds.......do that!
The 06 is WAY different from the 05.....
drbill
Posted: December 07, 2005 at 10:57 PM / IP Logged
i am using viper 791xv. no way to delay start. The green white wire you told me about is 12v + while the glow plugs are on, but it stays on even after I start with the key after the light on dash goes out. I would rather not use a timmer. is their a way to conect it to the dash bulb?
