2006 Camery se
Welcome Guest :)
civic_tt
Member -
Posted: December 04, 2005 at 6:32 AM / IP Logged
Looking for wiring diagram for 2006 Toyota Camery SE
Mike M2
Platinum -
Posted: December 04, 2005 at 7:12 AM / IP Logged
| 12volts | WHITE/ red (30A), white (5A) | + | ignition harness | |
| Starter | BLACK/ white | + | ignition harness | |
| Second Starter | BLACK / YELLOW | + | ignition harness | |
| Ignition | BLACK/ red | + | ignition harness | |
| Second Ignition | BLACK / YELLOW | + | ignition harness | |
| Third Ignition | N/A | | | |
| Accessory | blue/red | + | ignition harness | |
| Second Accessory | N/A | | | |
| Keysense | blue | - | ign harn or BECU, top plug, pin 19 | |
| Power Lock | blue / YELLOW | - | DKP or bottom of fusebox, 20 pin plg | |
| Power Unlock | blue (double pulse) | - | DKP or BECU, top plug, pin 22 | |
| Lock Motor | blue/red | 5wi | DKP or bottom of fusebox, 13 pin plg | |
| Unlock Motor | blue/black | 5wi | DKP or BECU, bottom plug, pin 11 | |
| Parking Lights+ | green | + | DKP or bottom of fusebox, 20 pin plg | |
| Parking Lights- | red | - | switch or BECU, top plug, pin 8 | |
| Hazards | lt. GREEN/ black | - | switch or BECU, middle plug, pin 10 | |
| Turn Signal(L) | GREEN / WHITE | + | turn signal flasher relay in DKP | |
| Turn Signal(R) | GREEN/ YELLOW | + | turn signal flasher relay in DKP | |
| Reverse Light | RED / black | + | DKP or bottom of fusebox, 20 pin plg | |
| Door Trigger | see notes | - | see notes | |
| Dome Supervision | GREEN/ red | - | ignition key cylinder light | |
| Trunk/Hatch Pin | green | - | DKP or BECU, bottom plug, pin 6 | |
| Hood Pin | black | - | theft deterrent ECU behind glovebox | |
| Trunk/Hatch Release | WHITE/ blue | 5wi | DKP or BECU, bottom plug, pin 12 | |
| Power Sliding Door | N/A | | | |
| Factory Alarm Arm | arms with lock | | | |
| Factory Alarm Disarm | disarms with unlock | | | |
| Disarm No Unlock | use key sense wire | | | |
| Tachometer | BLACK/ orange | ac | ECM behind glovebox | |
| Wait to start | N/A | | | |
| Brake Wire | GREEN / WHITE | + | sw or bottom of fusebox, 20 pin plug | |
| Parking Brake | RED / white | - | parking brake switch | |
| Horn Trigger | GREEN/ black | - | sw or bottom of fusebox, 24 pin plug |
Mike M2
Tech Manager
CS Dealer Services
Saturday, April 18, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
