truck starts and still engages when runni
jrs66ss
Member - Posts: 7
Posted: December 08, 2005 at 7:49 PM / IP Logged
aftermarketgeneration keyless entry alarm and remote start. all seems fine except when 1992 dodge dakota starts the starter is still engaging when running? checked tach wire all voltages seen fine what else should i try.
jrs66ss
05gt
Silver - Posts: 628
Posted: December 08, 2005 at 9:05 PM / IP Logged
are you sure you have the right tach wire, if you do have the right wire, tach has to be programmed did you do that
boomer_106
Silver - Posts: 710
What did you use for a tach source?  Did you try gray at the ignition coil?
jrs66ss
Member - Posts: 7
Posted: December 09, 2005 at 10:22 AM / IP Logged
i used black with grey stripe.and no i didnt program tach.ill check thanks
jrs66ss
Platinum - Posts: 12,488
Posted: December 09, 2005 at 10:51 AM / IP Logged
The tach wire on this truck is actually GRAY at the coil.
