2005 Toyota Sienna Alarm/Remote Start Wiring
Johnnynguyen20
Copper - Posts: 89
Posted: December 13, 2005 at 4:19 PM / IP Logged
does anyone have a wire diagram for this vehicle? 2005 toyota sienna. thanks for help
Johnnynguyen
chris354
Silver - Posts: 253
Posted: December 13, 2005 at 7:05 PM / IP Logged
12volts wht/red (30A), wht/blue (7.5A) +  ignition harness
Starter BLACK / YELLOW  +  ignition harness
Second Starter N/A
Ignition black  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory pink  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock lt. green  -  driver kick, 18 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue (double pulse)  -  driver kick, 18 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue / YELLOW (-) in the passenger kick in a 12 pin plug.
Lock Motor blue/red  5wi driver kick, 12 pin plug
Unlock Motor WHITE/ red to red  5wi driver kick, 18 pin plug
Parking Lights+ do not use, relay rests at gnd
Parking Lights- GREEN/ black  -  headlight switch
Hazards BLACK/ orange  -  hazard switch
Turn Signal(L) GREEN/ black  +  R side of fuse box, 30 pin plug
Turn Signal(R) GREEN/ YELLOW  +  R side of fuse box, 30 pin plug
Reverse Light RED / black  +  driver kick, harness to rear
Door Trigger blue  -  interior light switch on dash
Notes: Can also use individual door trigger wires. The driver door is RED / yellow in the 16 pin plug, pin 14 at the BECU. The passenger door is RED / yellow in the 28 pin plug, pin 23 at the BECU. The left sliding door is gray, pin 19, in a 25 pin plug on the right side of the fuse box. The right sliding door is RED / white in the 16 pin plug, pin 16 at the BECU. The hatch door is GREEN / WHITE in the 28 pin plug, pin 25 at the BECU. Use all wires and diode isolate each.
The BECU (Body ECU) is attached to the back of the fuse box under the driver side dash.
Dome Supervision RED / green  -  interior light switch on dash
Trunk/Hatch Pin common with door trigger wire
Hood Pin RED / white  -  BECU, 10 pin plug, pin 10
Notes: The BECU (Body ECU) is attached to the back of the fuse box under the driver side dash.
Trunk/Hatch Release yellow/red (power back door)  -  bottom L of fuse box, 22 pin plug
Notes: On vehicles without the power back door, the hatch release is GREEN/ black (-) at the BECU, 28 pin plug, pin 3. Meter this wire while open the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/black (+) at the BECU, 26 pin plug, pin 1.
Power Sliding Door YELLOW /GREEN (L), purple (R)  -  bottom L of fuse box, 22 pin plug
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange  ac  ECM, top plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / white  -  R side of fuse box, 36 pin plug
Horn Trigger GREEN/ black  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 Toyota Sienna Alarm/Remote Start Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on LE, XLE, and XLE Limited models
Johnnynguyen20
Copper - Posts: 89
Posted: December 13, 2005 at 9:53 PM / IP Logged
Thank you very much CHRIS354. You are a man.
Johnnynguyen
Mike M2
Platinum - Posts: 2,652
Posted: December 14, 2005 at 6:46 AM / IP Logged
I had one the other day that came back because the rear hatch wouldn't trigger the alarm. The tech sheet says blue at the switch, but for some reason this van would only trigger the other 4 doors on that wire. I ended up hooking the hatch up separately to make it work. I've done dozens of these vans and never noticed it before. I'm doing one today and i'm gonna check this out...
Mike M2
Tech Manager
CS Dealer Services
Johnnynguyen20
Copper - Posts: 89
Posted: December 14, 2005 at 11:29 AM / IP Logged
you and try the  GREEN / WHITE in the 28 pin plug, pin 25 at the BECU.
Johnnynguyen
