clutch switch bypass 96 s-10
ccroadshopinokc
Posted: December 19, 2005 at 11:30 AM / IP Logged
i got 4 wires, 1 is not active until the clutch is pressed, then it grounds until cranking in which it goes hot
one is ground at all times
one is hot at all times and the las one is ground until cranking, then it goes hot.
please help
tragik
Copper - Posts: 169
Posted: December 19, 2005 at 2:22 PM / IP Logged
Most likely the one that does nothing until the clutch is pressed and then goes hot during crank it the one you are looking for. to test it, turn the ignition on, an dthen take a FUSED lead and apply 12 volts + to the wire in question. If the car starts, then thats the wire you need. Just take the starter wire from the remote start drectly to it instead of at the ignition switch. Make sure the car is in neutral when you do this or you might die. Thats a heavy price to pay for convienience.
Northstart.....or start it your damn self.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 19, 2005 at 3:20 PM / IP Logged
TRAGIK....nicely put
mistahiggs
Member - Posts: 29
Posted: December 19, 2005 at 10:31 PM / IP Logged
is it legal for CC to install a RS on a standard in OK?
mobile1
Silver - Posts: 479
Posted: December 20, 2005 at 4:02 PM / IP Logged
if you have a PURPLE / white wire at the clutch switch, this is your starter wire. done
