Connecting 556HW to Prestige APS996a
spooken
Member - Posts: 25
Posted: December 20, 2005 at 1:40 AM / IP Logged
Hi guys,
My 03 Honda Accord currently has a 556U installed as the bypass module for Prestige APS996a. I want to change to 556H(W) so I can get my key back. I'm a little confused on how to connect the bypass module to the remote starter brain. The brain basically has a "2-pin Transponder Control Output" while the bypass module only shows that I need to connect just 1 cable.
The question is how do I do about doing this? Here are the PDFs to the Prestige APS996a and DEI 556H(W) installation manuals
Prestige APS996A Manual - See page 14 & diagram @ page 25
DEI 556H(W) Manual - See page 2 - 03 Honda Accord
redpeppers
Silver - Posts: 483
Posted: December 20, 2005 at 2:05 AM / IP Logged
the 556u only uses 3 wires ...a red , black and blue......put the red to the red on the 556h and the black and the blue to the blue white....then follow the wire diagram the wire in the rest of the wires.....
Where theres is a wire there's a way.
spooken
Member - Posts: 25
Posted: December 20, 2005 at 11:13 AM / IP Logged
[QUOTE]the 556u only uses 3 wires ...a red , black and blue......put the red to the red on the 556h and the black and the blue to the blue white....then follow the wire diagram the wire in the rest of the wires.....[/QUOTE]
Just want to confirm, I need to put the black and blue from 556U to just one cable on 556H which is Blue/White?
