Trouble installing a JVC kd-g 401
sappy
Posted: December 21, 2005 at 5:03 PM / IP Logged
Hello, I'm having some trouble installing a jvc kd-g 0401 into my girlfriend's car (a 1995 Seat Ibiza). It comes on for about 5 seconds then switches off. The fuse doesn't appear to be visibly affected, and it starts up every time, but I can't get it to stay switched on. Any suggestions as to what the problem might be, or what I could do? I'm basically a beginner to the whole thing. Any advice is appreciated.
JdM xplod b01
Copper - Posts: 73
Posted: December 26, 2005 at 1:17 AM / IP Logged
Check the ground c if its tight. Or check all your connections, i cant think of anything else, mayb it could be your deck
Pioneer Premier TS-w3004spl, Bass Slammer vented, Kenwood KDC MP-4028, and a KAC-9152d.
ss-installer
Silver - Posts: 444
Posted: December 26, 2005 at 7:53 AM / IP Logged
start the car up before you turn it on. you may be getting too low voltage (battery low) and make sure the ground is good.
sappy
Posted: December 26, 2005 at 9:12 AM / IP Logged
Thanks for the replies.
Just to shed a bit more light on the situation, my girlfriend's original car stereo (a Blaupunkt) still works fine when I put it back in (so I don't think its low battery or bad wiring). However I am using the wiring that was already in the car when I removed this Blaupunkt unit, same connections etc (I didn't see the point in changing them since everything was the same). Could this be causing the problem?
sappy
Posted: December 30, 2005 at 7:02 AM / IP Logged
OK, problem solved. I had a friend take a look. Apparently the permanent live wasn't connected. It wasn't necessary for the previous system but was for the JVC unit. Thanks for you replies, I appreciate the help.
