93 nissan maxima GXE remote start
adroga
Member - Posts: 7
Posted: December 22, 2005 at 6:44 AM / IP Logged
Hi Guys,
I am trying to install a prostart 3400C 2 way remote starter on my car. I thought I had found most of the correct wires, if not all, and when I hooked the wires up to the brain and attached the battery back, the brain began vibrating. I dont mean vibrating like a cell phone or pager, its more like some actuator is going crazy in there.
I noticed that with the headlights on it stops, which indicated that maybe this might be a source of the problem.
WIth the lights on, the remote start doesnt respond in any way.
I was told by someone on a maxima site that I didnt need the starter kill relay, external trigger input and I didnt need the ground out while running.
Lastly, I just realized that the instructions require a negative connection for the parking lights input, but my parking light wire gives me a ppostive voltage. How can I invert this?
Thank you for any help.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 22, 2005 at 6:15 PM / IP Logged
parking lights, POS(+) at the switch RED / yellow.
Did you ground the unit properly?
Craig3708
Copper - Posts: 155
Posted: December 22, 2005 at 6:58 PM / IP Logged
The prostart gives you two park light wires. A (+) yellow wire in the 5 wire harness, and a (-) orange in the 12 pin harness. Also as Kartuneman asked it sounds like a bad ground.......
Craig
adroga
Member - Posts: 7
Posted: December 22, 2005 at 10:16 PM / IP Logged
What about the ground out while running?
It was suggested to me not to use it, did I make a mistake by not using it?
Craig3708
Copper - Posts: 155
Posted: December 23, 2005 at 4:03 PM / IP Logged
The ground out when running is only used to provide ground to and external device (such as a bypass unit), while the vehicle is running on the remote start unit.
Craig
