2000 toyota solara alarm/remote start
hari-bhari
Member - Posts: 12
Posted: December 26, 2005 at 11:04 AM / IP Logged
i am having a strange problem with my handbrake while trying to install my remote starter. it is supposed to read 12v when not engaged, and ground when it is engaged. instead it is reading +1V when engaged, and 12V when not engaged. somehow, my starter still works whether or not the handbrake is engaged. does anyone have any ideas?
ringojam
Copper - Posts: 215
Posted: December 26, 2005 at 10:01 PM / IP Logged
Check the plunger switch at the hand brake and see if it makes ground or not,type and year of veichle would be helpful.
Jamaica home of the worlds fastest man.
redpeppers
Silver - Posts: 483
Posted: December 26, 2005 at 11:26 PM / IP Logged
does the brake light in the guage cluster come on?
Where theres is a wire there's a way.
hari-bhari
Member - Posts: 12
the car is a 2000 toyota solara. i am tapping the handbrake wire behind my gauge cluster at one of the plugs
redpeppers
Silver - Posts: 483
Posted: December 26, 2005 at 11:30 PM / IP Logged
r u sure that it is the right wire?
hari-bhari
Member - Posts: 12
Posted: December 27, 2005 at 12:36 AM / IP Logged
i mean i think it is... it shows +12V when the handbrake is not engaged and +1V when the handbrake is engaged.  don't know what other wire would do that....
hari-bhari
Member - Posts: 12
Posted: December 27, 2005 at 12:37 AM / IP Logged
the wire registers 12v when the brake is not engaged and 1v when it is engaged...
hari-bhari
Member - Posts: 12
Posted: December 27, 2005 at 1:02 AM / IP Logged
i hooked up my tach sense wire from my remote starter to the appropriate wire (which i tested) coming out of hte ecm on my 2000 toyota solara. however, after doing so, the rpms stopped being registered at all on my tachometer. it jus stayed at zero. does anyone know why this would be? also, right now i have the starter set to alternator mode to detect hte voltage spike when the car turns on. seems to be working fine, i am only worried that during a cold start it might need a little longer to start and the unit wont give it long enough. any suggestions?
hari-bhari
Member - Posts: 12
Posted: December 27, 2005 at 1:04 AM / IP Logged
i accidentally hooked up a +12v to the negative parking light trigger in my 2000 toyota solara. now the lever to switch on hte headlights doesnt turn on my parking lights or the interior lights. however if i light hte car's nighttime sensor turn the lights on for me and i leave the lever in the off position, everything works as normal. what have i done and how could i fix it? thanks!
