1995 Cavilier Problems
mikee2122002
Member - Posts: 21
Posted: January 06, 2006 at 7:04 AM / IP Logged
I have a 2w900fmr and I want to know if anyone can help me hook it up
I have the basic hooked up like the power ground and starter kill but i need to know how do i program my remotes with the alarm. Is thats a possibility that my antenna can be bad?
Do i have to hook up all wired before i can program the remotes?
Can some plz tell me whats the purple wire for on the relay and do i need it?
Also can someone tell me what do i need to hook statues to and ignition output too? plz help
OhioMike1101
Silver - Posts: 343
Posted: January 06, 2006 at 7:55 AM / IP Logged
the manual tells you how to program the remotes
South Side Audio
2501 S. High St
Columbus, OH 43207
mikee2122002
Member - Posts: 21
Posted: January 06, 2006 at 2:11 PM / IP Logged
yah i know but i need help now with the triggers for the doors what do i need to hook them up to to work
Platinum - Posts: 12,488
Posted: January 06, 2006 at 4:15 PM / IP Logged
You need to have most of the CN1 harness hooked up in order to program the remote as well as having the antenna plugged into the CPU. You do not need to have any of the triggers, sensors or other wire harnesses installed in order to have the system learn a remote control.
jacqueslacombe
Copper - Posts: 124
Posted: January 08, 2006 at 5:12 AM / IP Logged
Well  Make sure you don't have the passlock feature  because you won't get the car started    I know some 95 model as it  and some don't
cocolaboy
mikee2122002
Member - Posts: 21
Posted: January 08, 2006 at 3:23 PM / IP Logged
i know i check that and it don't have it
do anyone know anything about compustar alarms systems plz pm me or post it here
tech support i called them and they don't know shhh
mikee2122002
Member - Posts: 21
Posted: January 08, 2006 at 10:19 PM / IP Logged
ok thx anyway but can anyone tell me why  when my car try to remote start it shuts right back off
i have a 95 cavalier that don't need a bypass
