Matrix rsx 3.5 on a 2005 Tahoe
ago0606
Member - Posts: 7
Posted: January 08, 2006 at 10:18 PM / IP Logged
I have had my 3.5 installed since Dec. 2004. Now, when I arm my Tahoe,  the alarm starts going off. I push the button and in 15-20 seconds my remote sounds and the alarm triggers for no reason. I discovered that if I manually lock my door and then set the alarm, it doesn't go off.
Any ideas as to the cause of this?
ago
kgerry
Platinum - Posts: 3,455
Posted: January 09, 2006 at 3:14 PM / IP Logged
push in the domelight overide and see if you have the same problem.... this will narrow down whether its the door circuit or not.... when you say it triggers for "no reason" what is the LCD screen showing you???
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
ago0606
Member - Posts: 7
Posted: January 09, 2006 at 7:11 PM / IP Logged
The LCD screen shows the shock sensor ( the hammer in the middle of the car, right?)
Now that I have used the power locks on the door before arming, the alarm only shows a warning and chirps instead of going off. Butt it does this for every little sound. Like the sensitivity was increased. But would that cause the alarm to go off when arming it without locking the doors 1st. (would it be ultra sensitive to anything? even the dome light delayed in going off?) Is that a stupid question?
And how would the sensitivity increase on its own? If that is a possibility.
ago
sparkie
Platinum - Posts: 2,061
Posted: January 09, 2006 at 7:14 PM / IP Logged
The sensor could be defective or it may have moved or come loose from its mounting location. This would change its reaction to vibration. Inspect it to see if it held tight or has moved.
sparky
kgerry
Posted: January 10, 2006 at 8:14 AM / IP Logged
as sparkie said, visually check the shock sensor....'i've seen where the wire tie breaks that the shock sensor was mounted with and it's now swinging by it's wires.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
ago0606
Member - Posts: 7
Posted: January 28, 2006 at 7:08 PM / IP Logged
thanks everyone
ago
