Viper 550 Install
jwalk1818
Posted: December 23, 2002 at 8:09 PM / IP Logged
Ok I just recieved my Viper 550 from my girl for xmas and I cant afford right to pay someone to install it casue their wanting 175 to do it! Well who on here can help me out? I need complete help!
99 Toyota Celica
AIM NAME: JWalk1818
trusdamanr
Copper - Posts: 116
Posted: December 23, 2002 at 8:31 PM / IP Logged
12volts
Viper 550 Install - Last Post -- posted image.
 white - BLACK/ red
 ignition harness
Starter BLACK/ white   +  ignition harness
Second Starter none
Ignition black   +  ignition harness
Second Ignition blue/red   +  ignition harness
Third Ignition none
Accessory gray   +  ignition harness
Second Accessory none
Keysense
Power Lock blue/black   -  lock module right of column
Power Unlock blue and green   -  lock module right of column   Viper 550 Install - Last Post -- posted image.
Lock Motor none  non none
Unlock Motor none  non none
Parking Lights+ dk. green   at dimmer
Parking Lights- lt. green   steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  drivers kick panel   Viper 550 Install - Last Post -- posted image.
Dome Supervision none  non none
Trunk/Hatch Pin RED / green   -  drivers kick panel   Viper 550 Install - Last Post -- posted image.
Hood Pin none
Trunk/Hatch Release none
Power Sliding Door
Factory Alarm Arm none
Factory Alarm Disarm none
Disarm No Unlock none  non none
Tachometer gray    check connector   Viper 550 Install - Last Post -- posted image.
Wait to start
Brake Wire GREEN / WHITE   +  drivers kick panel
Parking Brake
Horn Trigger green   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
1.door unlock note-Use both wires and diode isolate each.
2.door trigger and trunk note-Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape.
Immobilizer By Pass : Not Available
MAKE : TOYOTA | MODEL : CELICA | YEAR : 1999
par3721
Member - Posts: 26
Posted: December 24, 2002 at 4:09 AM / IP Logged
if you don't know what your doing WAIT and save yourself alot of trouble. pay for someone to install in it so if there is any trouble you will not be responsible.
Platinum - Posts: 12,488
Posted: December 24, 2002 at 9:55 PM / IP Logged
If you do not have electronic back ground or never installed or taken apart the car before, I would let a professional take the job. Even if it costs $ 200 + thta's still cheaper than a new BCM or ECM if you were to short out the module or worse hurt yourself.
