2004 Silverado starter interrupt
xxaana
Posted: January 16, 2006 at 9:04 PM / IP Logged
Attempting to install an Audiovox AX-510 and I am having difficulties finding the correct starter interrupt wire. Does anyone have the correct color scheme and location of the wire(s)?
fingaz22
Silver - Posts: 410
Posted: January 16, 2006 at 9:13 PM / IP Logged
12volts red (x2)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
On base model trucks, the 457G or 456G is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock see power lock
Lock Motor gray   5wi driver door module in door
Unlock Motor tan   5wi driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   steering column, 5 pin plug
Turn Signal(L) dk. green   +   steering column, 5 pin plug
Turn Signal(R) lt. green   +   steering column, 5 pin plug
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger gray/blk (L), BLACK/ wht (R)   -   each door module in each door
Notes: On base model trucks the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. On 4dr trucks the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM. Use all wires and diode isolate.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start dk. blue   -   instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the green plug, pin 36.
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   BCM, lt. blue plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   steering column
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 555LW
Alternate Part1 #: 555T
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and RED / white (not used).
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 456G
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes:
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
05gt
Silver - Posts: 628
Posted: January 16, 2006 at 11:10 PM / IP Logged
do you mean the starter wire in the vehicle or the wire you use off of the alarm brain
the starter wire in the vehicle is yellow and the wire you use of the brain is orange
xxaana
Posted: January 17, 2006 at 12:23 PM / IP Logged
The wire off of the vehicle.  But the wire that only has power when the starter is turning....
extreme1
Silver - Posts: 1,070
Posted: January 17, 2006 at 2:58 PM / IP Logged
the vehicle has built in starter kill/anti grind.
no need to install an aftermarket one.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
xxaana
Posted: January 17, 2006 at 8:23 PM / IP Logged
Thank You!!!!  One more question which wire will flash all the tail lights the only ones I can find flash each light seperatly.
extreme1
Posted: January 18, 2006 at 4:53 PM / IP Logged
grey/black (-) at the middle connector at the BCM
Shaughn Murley
Visions Electronics
Red Deer, Alberta
