89 Nissan 240sx
watduhfunk
Posted: January 17, 2006 at 6:04 PM / IP Logged
i just got an astra 777 alarm for my '90 240sx. i got everything to work excecpt for unlocking the door. it locks perfectly fine but once i try to unlock it nothing happens. can anyone help me with this?
-WaT DuH FuNk-
cntrylvr79
Silver - Posts: 582
Posted: January 17, 2006 at 7:27 PM / IP Logged
Power Lock ORANGE / black   F  driver kick panel
Notes: This is one of the three known systems Nissan used in early production. To operate, open(cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock. The other two systems are negative pulse (ORANGE / black for lock and ORANGE / blue for unlock both at the door lock timer in the passenger kick behind the ecm.) and non-centralized - add actuator in drivers door.
So Which setup is your car?
Cause I'm So white and nerdy...
First Class Certi-fried installer
watduhfunk
Posted: January 23, 2006 at 4:49 PM / IP Logged
hey everyone!
wondering if anybody could help me out...i THINK i blew out a fuse doing some electrical work on my car (i forgot to undo the battery)....so now my car wont start. i turn the key and get nothing. i know the battery is fine because the lights work and my alarm is still on. absolutly nothing happens! any ideas on what it is?
-WaT DuH FuNk-
cosmoworks
Copper - Posts: 144
Posted: January 24, 2006 at 7:48 PM / IP Logged
It doesn't even crank?  In your car the key supplies power to the Interlock relay which supplies power to the starter solenoid.  Is your car M/T or A/T?
Sounds like you just blew a fuse however.
