lock wires, 2004 jeep liberty
hexnut
Member - Posts: 21
Posted: January 20, 2006 at 11:03 PM / IP Logged
Hello,I need to know which wires do what,I have 4 going to my drivers lock switch.1 should be neg 1 should be illuminate 1 lock and 1 unlock,anyone know the colors of which 1 does what?I am not getting proper readings or voltage changes from locking or unlocking.Thank you.The vehicle is a 2004 jeep liberty.
OhioMike1101
Silver - Posts: 343
Posted: January 20, 2006 at 11:06 PM / IP Logged
they  are multiplexed!
South Side Audio
2501 S. High St
Columbus, OH 43207
hexnut
Member - Posts: 21
Posted: January 20, 2006 at 11:09 PM / IP Logged
Sorry ohiomike but I don't know what that means lol.
hexnut
Member - Posts: 21
Posted: January 20, 2006 at 11:28 PM / IP Logged
Ok,did a search and kinda know what that means but it still doesn't help me on which wires to hook to?
hexnut
Member - Posts: 21
Posted: January 21, 2006 at 11:01 AM / IP Logged
Can anyone tell me how to test for the lock unlock wires as in what kind of readings I should be getting?
mo12v
Posted: January 21, 2006 at 12:24 PM / IP Logged
I iuse the OMEGA DB-CHDL4P or DB-CHDL4
But you can hardwire:
Power LockPINK/VIOLET**AT BCM ON BACK OF
Power UnlockSINGLE WIRE SYSTEMJUNCTION BLOCK IN DRIVER KICK PANEL
**Single Wire-Resistor Door Lock Circuit .
** Chassis Ground Thru 1.4K Ohm Resistor For Lock And A Chassis Ground Thru 425 Ohm Resistor For Unlock Also Found In Harness From Door High In Dr Kick ............Use Relays.
MO
hexnut
Member - Posts: 21
Posted: January 21, 2006 at 9:32 PM / IP Logged
Thanks for the input everyone.I got it installed and everything works.
zshopa
Member - Posts: 10
Posted: January 30, 2006 at 11:25 AM / IP Logged
got any pics of the connections for the lock and unlock?
or a quick runthrough of what you did, i want to do mine this weekend and dont seem to understand that part of it.
