upgrade to two subs
not4666
Member - Posts: 12
Posted: January 22, 2006 at 3:21 AM / IP Logged
I own a 2005 dodge quad cab. i had a fiberglass box built for 1 sub(only .55 cubic feet). my memphis mcd500 and polk 10" svc sub are only using 250 rms at 4 ohms (it sounds very nice). i would like it louder so i purchased a L5 10"(450rms @ 2ohm) in a sealed box it sounds a bit louder but my wife doesn't like the fact that i does not fit under the rear seat. I am thinking about buying a box that holds 2 10"subs under the rear seat and 2 memphis pr10s. i will either buy a wood box(1.4 cubic ft.) or a MTX thunderform(1.5 cubic ft.). Has any one heard either of these two setups. also i have read in other posts that going from one sub to two subs will only give 3 decibels more. if this is true is it really worth the extra expense?
stevdart
Platinum - Posts: 5,816
Posted: January 22, 2006 at 12:02 PM / IP Logged
It will yield more than +3 db for a few reasons.  The +3 db is just for the doubling of cone area.  You also have to weigh in with the fact that you would be giving the second sub power;  if each sub is given the amount of power the original lone sub had, there is another +3 db due to the doubling of power.  Then there is the cabin gain increase (unknown quantity) that will take place due to factors 1 and 2.
Then, of course, there is the added decibels due to voice volume when everybody has to shout to be heard over the music...   ;)
I'll leave your first question open as I've not experienced the Thunderform.  But from what I've heard on this forum from respected people it is a good enclosure.
