2004 silverado SS pats 2 Bypass
trtex
Member - Posts: 25
Posted: January 22, 2006 at 11:46 PM / IP Logged
Recently installed a remote start and a PLZAP Bypasskit bypass in a 2004 Silverado. Everthing works fine except the security light stays on all the time. I think I figured out that this Bypass is the wrong one. Which should I be using....PLJX Bypasskit or DEI model or what?????  Thanks!
redpeppers
Silver - Posts: 483
Posted: January 23, 2006 at 12:41 AM / IP Logged
sounds like u have it wired wrong.......i have never used a pljx...but i have never had any probs with DEI bypass mods.... (not to say that to one u used is bad)  Give us the info on how u wired and maybe we can help.
Where theres is a wire there's a way.
trtex
Member - Posts: 25
Posted: January 23, 2006 at 6:40 AM / IP Logged
Did you understand I used a PLZAP??? According to the bypasskit.com web site, it's not listed to be used with the 2004 Silverado...so I'm looking for an alternative. With the PLZAP, the security light will not go off even if I use the key because it's not overiding the VATS as well...according to what I have read. The guy who sold it to me sold me the wrong one!!
kgerry
Platinum - Posts: 3,455
Posted: January 23, 2006 at 8:43 AM / IP Logged
457G or 555L or 556L or PLJX or XK01.....
any of these will work and be correct.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
trtex
Member - Posts: 25
Posted: January 23, 2006 at 9:21 AM / IP Logged
Thanks!!!
trtex
Member - Posts: 25
Posted: January 23, 2006 at 2:41 PM / IP Logged
Installed remote start. Used Bypasskit PLZAP bypass..Works fine except Security light stays on even when using just a key to start.....will changing bypass to a PLJX Bypasskit solve the problem? The supplier of the PLZAP says to try wiring it to the Neg. on relay pack so it won't drop out during cranking and this will solve my problem. I've ordered the PLJX anyway. Thoughts?
