04 Dodge Ram diesel remote start
diamondbrite
Member - Posts: 8
Posted: January 30, 2006 at 7:35 AM / IP Logged
Installed a 1wam-as and everything seems to be working fine. The only problem I have is the "check engine" light came on and I cannot figure out why. I hooked up a scanner and no faults were found. Check all the wiring and everything looks good. Maybe someone here ran into this situation.
redpeppers
Silver - Posts: 483
Posted: January 30, 2006 at 12:16 PM / IP Logged
did u hook up all accessory and all ignition wires
Where theres is a wire there's a way.
amazingaudio
Member - Posts: 22
Posted: February 01, 2006 at 11:45 AM / IP Logged
Double check the igintion wires. If I remember right there are a couple dofferent wires there that are the same color that meter the same for the ignition. I think its blue. If you get the wrong one it will start and run fine, but the SES light will come on.
bazzgazm
Copper - Posts: 113
Posted: February 01, 2006 at 2:59 PM / IP Logged
ooh =)
did you do wait to start?
if so. make sure your alarm has "accessory on durring wait to start"
heh.
did one of these a few days ago and had the same trouble. the only difference i saw was the accessory wasn't powered, did some research and found out that if it's not. you'll get check engine, abs and brake lights all on.
