Wiring Diagram for 05 Acura EL
vibn
Posted: February 01, 2006 at 2:28 PM / IP Logged
Does anyone have the wiring Data for the 05 Acura EL
Joe Neal
Copper - Posts: 113
Posted: February 01, 2006 at 8:33 PM / IP Logged
Is that EL or TL?
Joe Neal
Copper - Posts: 113
Posted: February 01, 2006 at 8:35 PM / IP Logged
 EL:
Constant 12 voltsWHITE AT FUSE BOX TOPGREEN 5 PIN CONNECTOR *
Ignition 12 voltsBLACK / YELLOW AT FUSEBOX GREEN 5 PIN CONNECTOR *
StarterBLACK/ WHITE AT FUSEBOX GREEN 5 PIN CONNECTOR *
Dome LightDOOR PINS (-) FOUND ATFUSE BOX CENTER ROW GREEN 8 PIN * **
Trunk Pin SwitchBLUE / YELLOW (-) AT SECURITY MODULE WHITE 20 PIN CONN ***
Parking LampRED / YELLOW (+) AT FUSEBOX GREEN 18 PIN CONNECTOR *
Power LockWHITE/ BLUEWHITE CONNECTOR ABOVE DR KICK
Power UnlockWHITE/ GREENWHITE CONNECTOR ABOVE DR KICK
Negative Pulse Door Locks
* Fuse Box Is Located Under Drivers Dash. ** Door Pins:Drivers GREEN, Passengers L GREEN/ RED,Drivers Rear And Passengers Rear GREEN / WHITE. *** Security Module Is Located Under Drivers Dash Just Above Brake Pedal
Accessories
Window Up
Window Down
Ign Key WarnBLUE/WHITEAT IGNITION HARNESS
Trunk ReleaseYELLOW /GREEN (+)MODULE ABOVE DRIVER KICK
OEM HornORANGE (-)8 PIN CONNECTOR TOP LEFT OF FUSE BOX*
HeadlightsBLUE/RED (-)AT SECURITY MODULE **
OEM Alarm ArmWHITE/ RED (-)DRIVERS KICK PANEL
OEM Alarm DisarmWHITE (-)DRIVERS KICK PANEL
* Fuse Box Is Located Under Drivers Dash. ** Security Module Is Located Under Drivers Dash Just Above Brake Pedal
Remote Start
Tach SignalBLUE GREEN 13 PINCONNECTOR AT TOP RIGHT OF FUSE BOX
Ignition #2
Ignition #3
AccessoryBLACK/ RED TOP ROW OFFUSE BLOCK BOX GREEN 5 PIN CONNECTOR
Neutral Safety
Brake LightWHITE/ BLACK (+) GREEN13 PIN CONN AT TOP RT OF FUSE BOX
Reverse Light
Rear Window DefrostYELLOW/BLACK (-)IN PASSENGERS SIDE CONSOLE HARNESS
Immobilizer Bypass
At Security Module In WHITE 20 Pin Connector located Above Brake Pedal: Right Rear Door Pin : GREEN / WHITE (-) OEM Hood Pin :GREEN/ BLACK (-) Trunk Release: YELLOW /GREEN (+) Drivers Door Pin : GREEN (-) RF Door Pin : L GREEN (-) Key Sensor : RED / WHITE (-) Trunk Pin : BLUE/ YELLOW (-) Arm Security Only : WHITE/ RED (-) Disarm Security Only : WHITE (-) To Also Unlock Pulse Two Times
