subaru wrx sti 2005 radio reception probl
TomTibeau
Member - Posts: 8
Posted: February 02, 2006 at 4:40 PM / IP Logged
Hello, I'm trying to install an alpine cda9855 in a impreza wrx sti 2005. The problem is that I am not able to set the radio to receive it correctly. The catch of antenna of the vehicle is standard and well connected. The standard radio (manufacturer original) is able to take an impressionant number of radio stations. I would like to know, initially, where is the antenna (no apparent antenna)? Secondly, I like to know how I can have a better reception of the radio without having to change the antenna? If somebody had already have this problem or can help me , thank you a lot. Bye
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2006 at 4:45 PM / IP Logged
The antenna on this vehicle is like a VW....it needs 12volts....
Power Antenna white  +  radio harness
craniumvibratio
Copper - Posts: 55
Posted: February 02, 2006 at 5:50 PM / IP Logged
whats up. I have not had the pleasure of a deck slam with an 05 wrx. But i have one coming in on saturday and was wondering if there was any tricks to taking out the stock 6 disk? and maby step by step? That thing sux. anyways i appreciate the help.
Alpine Guy
Platinum - Posts: 2,478
Posted: February 02, 2006 at 8:42 PM / IP Logged
i did a 05 sti, to get the deck out just get a small flat screwdriver and pry the trim panels off, nothing spectacular.   As for the ant issue, i forget what i did, but it worked out great.
stealth raptor
Posted: February 03, 2006 at 4:49 AM / IP Logged
The WRX has a diversity antenna located in the rear windscreen and needs to have 12v supplied to it via the head unit remote wire. Some head units have both a amp remote and ant remote wire so check to make sure correct wire is used. The easiest way to find the ant remote power wire is reconnect the original h/unit, turn it on and test the wiring for power. There should be three wires that have power. Constant power, Acc power and the ant remote wire. Leave the Acc on and turn off the h/unit. The wire that loses power is the ant remote wire subaru wrx sti 2005 radio reception probl - Last Post -- posted image.
Hope this helps.
TomTibeau
Member - Posts: 8
Posted: February 07, 2006 at 1:02 PM / IP Logged
Tank you for your help. Now the radio work perfectly.
tom
