1999 Mustang + Autopage install
gpgtp00
Copper - Posts: 81
Posted: December 28, 2002 at 11:07 PM / IP Logged
Heres the deal... im installing a AutoPage Rs-750LCD model alarm/Remote Start on a 1999 Mustang. What Ide like to know is... a: what type of door locks is on this car and is there a way to bypass the Vats on this car? I looked at the wiring diagram, but it didnt say what type of locks it is. Normally it says on the bottom of the diagram wether its positive, negative, etc. Thanks in advance.
10nesne1
Silver - Posts: 284
Posted: December 28, 2002 at 11:19 PM / IP Logged
Ford
Mustang
1999-2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
WHITE/ PINK
IGNITION SWITCH HARNESS *
Ignition  #1:
RED / GREEN
Ignition #2:
RED / BLACK
IGNITION SWITCH HARNESS ***
Ignition  #3:
GRAY / YELLOW-2WIRES
IGNITION SWITCH HARNESS *** ****
Accessory:
BLACK/ LT. GREEN
Brake  Light:
RED / L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
ORANGE / WHITE
PIN #48 AT POWERTRAIN CONTROL MODULE **
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
D GREEN/ PURPLE (-)
BLACK 12 PIN CONN. DR. KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module Located In Passenger Kick Panel. ** Most Models Are Equipped With Ford's PATS Anti-Theft System - Use Universal Alarm Bypass Module. *** See Note #211 - Ford Ignition Switch Connection Diagram. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control a relay which powers ignition 3. The wire will also be connected to a bypass module, if needed.
Ford
Mustang
1999-2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
GREEN/ PURPLE
Starter  Kill:
WHITE/ PINK
Ignition  +12 Volts:
RED / GREEN
Dome  Lights/Superv:
BLACK/ WHITE
AT BCM ABOVE DRIVER'S KICK PANEL
OEM Horn:
PURPLE / ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
LT. GREEN
12 PIN BLACK CONNECTOR *****
Power  Unlock:
PURPLE
HIGH IN DRIVER OR PASS. KICK PANEL
Trunk  Release:
PURPLE / YELLOW (+)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
BLACK/ WHITE
Notes:
**** With OEM Keyless Entry Dome Light Wire Is GRAY (+) In 12 Pin Gray Connector In Driver Kick Panel. ****** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
