1996 Chevy Astro alarm/remote start wiring
joelw2005
Posted: March 08, 2006 at 9:18 PM / IP Logged
I'm going to install a Crimestopper CS-2016 2-Way FM Paging Alarm and Remote Start and I need the wiring colors of my van. It's a 1996 Chevy Astro with factory keyless entry, power windows, power door locks. If any body can help me out I'll be thankfull.
jw2006
fivestar
Member - Posts: 14
Posted: March 08, 2006 at 10:15 PM / IP Logged
why dont you know how to install a basic alarm
joelw2005
Posted: March 08, 2006 at 10:21 PM / IP Logged
This is not a Basic Alarm. I have to wiring diagram for  the alarm but not to my van. And I know that you can't match color for color.
jw2006
fivestar
Member - Posts: 14
Posted: March 08, 2006 at 10:28 PM / IP Logged
i didnt say that it was a basic alarm its the same shhh as a basic alarm ok basics just have to look for 3 more  wires thats it
fivestar
Member - Posts: 14
Posted: March 08, 2006 at 10:31 PM / IP Logged
go to the vehicle wiring on this web page
joelw2005
Posted: March 09, 2006 at 5:52 AM / IP Logged
fivestar I have the basic diagram for this alarm, but it doesn't give me the diagram for the remote start and keyless entry. can you help me or not?
jw2006
fivestar
Member - Posts: 14
Posted: March 09, 2006 at 11:20 AM / IP Logged
red
yellow   starter
pink
brown    Accesories
orange
those are your ignition
xscash
Copper - Posts: 317
Posted: March 09, 2006 at 2:09 PM / IP Logged
here you go.
 ASTRO  1996 -1997
 KEY T-HARNESS IMMOBILIZER
  N/A   GM-1   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
 IGNITION 2 PINK/WHITE (+) or WHITE (+) See NOTE *3 IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 ORANGE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) BROWN (+)  @ HEADLIGHT SWITCH or HARNESS heading to Rear of vehicle
 POWER LOCK LIGHT BLUE (TYPE A)  IN DRIVERS DOOR BOOT
 POWER UNLOCK WHITE (TYPE A)  IN DRIVERS DOOR BOOT
 DOOR TRIGGER PURPLE (-)  @ HEADLIGHT SWITCH
 DOMELIGHT SUPERVISION USE DOOR TRIGGER
 TRUNK RELEASE GREEN (-)  @ HATCH RELEASE SWITCH or at KEYLESS MODULE, See NOTE *1
 SLIDING POWER DOOR N/A
 HORN BLACK (-)  @ STEERING COLUMN HARNESS
 TACH WHITE  @ ECM, See NOTE *2
 WAIT TO START LIGHT N/A
 BRAKE WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 the FACTORY KEYLESS MODULE is located behind the RADIO and to the LEFT or at RELAYS in the PASSENGER KICK PANEL. NOTE *2 the ECM is located on the DRIVERS SIDE of the ENGINE COMPARTMENT, behind the BATTERY, in a BLACK Plug, labled "WHITE" NOTE *3 IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!!
