proximity radar sensor
jeryl
Member - Posts: 37
Posted: March 29, 2006 at 10:42 PM / IP Logged
i am trouble installing a bulldog radar sensor #703 to my bulldog pro series #7002 alarm... the trigger sensors are set all the way counterclockwise but still the alarm keeps getting triggered, ive wired the green as minor on and white as major as indicated in the bulldogsecurity.com website
jeryl
Member - Posts: 37
Posted: March 31, 2006 at 8:00 PM / IP Logged
the problem is the first stage or prewarning chirp is always chirping ... also when i connect the inner zone wire the alarm goes off all the time
floaterr
Silver - Posts: 383
Posted: April 02, 2006 at 10:07 AM / IP Logged
is it it mounted right above/near metal?
does it go off instantly everytime or after an hour or over night?
jeryl
Member - Posts: 37
Posted: April 02, 2006 at 8:57 PM / IP Logged
it is mounted right under the steering column and goes off immediately after i arm the alarm... i guess i should move it under the center of the car???
integratyper934
Copper - Posts: 150
Posted: April 02, 2006 at 9:26 PM / IP Logged
radar sensor is the problem i have installed 2 in both my cars and depending on the weather conditions temp etc the prox will always fault,and occassionally work properly. i would recomend getting rid of it unless you wanna keep coming out to your car in the middle of the night when its raining or something. or hook it up to an aux on the alarm or switch to turn it off.
